paper size switches R-2035
  • tcypy1961
    • 773
    [Electrical] paper size switches R-2035
    do these switches give problems alot??? dial is set for 8x11R yet display will read anything but. I've adjusted the bracket the switch is mounted on and it has helped on some copiers. I did pull one out the other day and I going to try cleaning the switch. Thanks!!!
  • TonerMunkeh
    Professional Moron
    • 3865
    They do go occasionally, usually as a result of the tray being belted back in by stressy customers.
    Hit it.
    • cobiray
      Passing Duplication Xpert
      • Mar 2008
      • 1199
      I would say rarely they are failed and need replaced. I can probably count on one hand the ones I had to replaced. Often there is paper or an incorrectly set paper guide causing the erroneous size detection. The ones that are troublesome I often screw down the guides and set the size through user tools.
