DSM 618
  • KHAN
    • Aug 2006
    • 261
    DSM 618
    Hello I have DSM 618 ,when make copies using any Tray the Print come out appoxi 7% Reduce, I check all the USER setting ,APS and RE ,all settings are at home position,
    Please need help.
    THANKS
  • TonerMunkeh
    Professional Moron
    • 3865
    Perform an engine clear (SP5801-3) and see if that sorts it.
    Hit it.
    • Jomama46
      • 2900
      Is it reduced on both planes? SP2998 and 4008 and 9 will adjust.
      sigpic
      A+; Network +; PDI+
      • KHAN
        • Aug 2006
        • 261
        Thanks friends for your replies, Today I reset the SP5 801 ALL MEMORY CLEAR but same result, yes it reduce from all sides, I also replace the hole SCANNER UNIT LSU but same result, I will check SP2 AND SP 4 tomorrow, WHAT is and 9 will adjust. Mr Jomama please.
        THANKS have a nice day to all.
        • Jomama46
          • 2900
          SP4008 AND SP4009 will adjust the Main scan and the Sub scan size for scanning. SP2998 will adjust the Printing Main Scan size.
          sigpic
          A+; Network +; PDI+
          • KHAN
            • Aug 2006
            • 261
            I change all SP setting but nothing, IMAGE REDUCE ONLY LENGTH WISE from any Tray and any size of paper.
            • KHAN
              • Aug 2006
              • 261
              At last i get the fault. my main PCB have the problem, right now i can change it, because it is expensive for me, OK when i select 112% enlarge the original I get 100% same copy.
              Each time we turn ON the copier display show 100% , I want it 112% whenever I turn ON the copier,Please how to memorized 112% ratio , Please need help,
              HAVE A NICE DAY .
              THANKS
              • Jomama46
                • 2900
                Set it as a User Program, then just use that program
                sigpic
                A+; Network +; PDI+
                • KHAN
                  • Aug 2006
                  • 261
                  THANKS for reply, Please explain me how to Set USER PROG and how can I use ?
                  THANKS
                  • Jomama46
                    • 2900
                    Set the control panel the way you want it, press the Program key and select a program number.
                    When you want to make a copy, press Program and then the program key number.
                    Its in the operator manual.
                    sigpic
                    A+; Network +; PDI+
                    • KHAN
                      • Aug 2006
                      • 261
                      OK thanks for your kind help and time,
                      Have a nice day
