CL4000 lines
  • Voltage
    • Jul 2008
    • 282
    CL4000 lines
    Hi guys
    If have a CL4000 thats got line in the solids of the colors. They run at a 60deg. angle.
    The file i added does not show exactly how it looks, but the back of the fish shows it best. Any ideas
  • TonerMunkeh
    Professional Moron
    • 3865
    Has it had any parts replaced yet? Laser glass cleaned? etc, etc.
    Hit it.
    • Voltage
      • Jul 2008
      • 282
      Only replaced the black pcu. The machine is fairly new. Cleaned the laser toner shield glass. The inside of the laser was clean. Seems like only the cayn and magenta that is doing it.
      magenta lines to the right and cayn lines is to the left.
      • TonerMunkeh
        Professional Moron
        • 3865
        That is rather bizarre. I'd try engine clear then update the firmware after that. If that doesn't work, controller board would be the next step.
        Hit it.
        • Voltage
          • Jul 2008
          • 282
          Did do an engine clear, but not a firmware update yet. Will do in tomorrow morning 1st thing
          • TonerMunkeh
            Professional Moron
            • 3865
            Saying that - try reseating any DIMMS and formatting the HDD first. Might be a memory issue. Does it do the same via USB and ethernet?
            Hit it.
            • Voltage
              • Jul 2008
              • 282
              It does it through ehternet and the printouts out of memory. Haven't tried usb but pretty sure it will do it too
              • Voltage
                • Jul 2008
                • 282
                Updated the firmware, still the same
                • TonerMunkeh
                  Professional Moron
                  • 3865
                  IPU board and possibly a laser unit next methinks.
                  Hit it.
                  • mikadonovan
                    • May 2008
                    • 2931
                    You may want to try another transfer belt unit. I've seen some strange problems come from a faulty TB, although never exactly like the problem your machine is exhibiting. The reason I'm saying this is because of the 60 degree thing. That may correlate to a transfer cleaning brush. I don't have one of those on hand to look at to see for sure.
                    NEVER ASSUME ANYTHING
                    • Voltage
                      • Jul 2008
                      • 282
                      Ok will try it tomorrow. Its now midnight in SA. Do you think the tansfer unit will have that kind of effect just on cyan and magenta cause yellow and black is fine
                      • Voltage
                        • Jul 2008
                        • 282
                        Still no joy with this machine.
                        Update firmware
                        Replaced transfer unit.
                        Replaced dev. unit.
                        Cleared memory.
                        I compared the test print from a mpc3000 and the cl4000 through a magnifing glass and what i found is that the mpc3000 (which is making a beautiful copy) test page had the same lines as the cl4000. The mpc3000 lines just looked like they are thicker or with more toner. You can not see the lines on the mpc3000 with the naked eye.
                        I checked i maybe there was something like toner save mode switched on, but could not find such a setting. Even the letter on the config page apears thinner on the cl4000 than the one from the mpc3000.
                        • TonerMunkeh
                          Professional Moron
                          • 3865
                          Board time methinks.
                          Hit it.
                          • msaeger
                            • Sep 2008
                            • 333
                            I saw that pattern on a different machine and it was the laser unit.
                            • Voltage
                              • Jul 2008
                              • 282
                              Ok Got it finally.
                              It was a thin layer of dust on the top mirror, which handles the magenta and cyan. How the hell did it get in there. Should have looked at that first.
                              Anyway thanks for everyones help.
