MPC3000 Username and Password Needed
  • mrfuser
    • 1615
    Okay, client inherited machine and username and password has been changed. supervisor, Admin, etc. all don't work. Tried Memory Clear and it still would not let us in either via the Web Interface or LOGIN button on copier itself. Is there any possible way to see what it is or a way around it?
    Kelly
    kelly@pcbmonline.com
  • aabarnes1
    • Mar 2009
    • 620
    You must return the machine to it's default settings- memory all clear will not work.
    Grant me the serenity to accept the things I cannot change.
    • mrfuser
      • 1615
      How do you return it to factory default settings??
      Kelly
      • TonerMunkeh
        Professional Moron
        • 3865
        NVram replacement is the only way on this breed I think.
        Hit it.
        • mrfuser
          • 1615
          nvram
          Where can I get another nvram?
          Clone from another aficio?
          Kelly
          • TonerMunkeh
            Professional Moron
            • 3865
            Nooooooooooooooooooooo lol don't try cloning one. You'll have to order another one from Ricoh. Don't try swapping the NVram and controller board from another machine unless it's another MPC3000 either. You'll knacker both boards.
            Hit it.
            • teebee1234
              • Jul 2008
              • 1670
              Cut and pasted the knowledge base answer below. The controller NVRAM # is B2309590
              Details [Problem]
              The Administrator and Supervisor password has been lost.
              Answer [Explanation]
              The Administrator and Supervisor Login User Name and Password can not be reset in SP Mode
              [Action]
              • Replace the NV RAM on the Controller PCB
              Do not remove the NV RAM until after you upload its contents to a SD or IC Card depending upon model.
              Always touch a metal surface to discharge static on your hands before you touchthe controller board.
              Work carefully when you remove the NV RAM, to prevent damage to othercomponents on the controller board. Do not short-circuit the pins of other chips.
              On models with more than one NV RAM, chips must always be removed and replaced as a pair.
              Be sure the notch on the chip is aligned with properly with the white stenciling on the PCB, do not use the label on the chip for alignment as label placement may vary.
              • mrfuser
                • 1615
                Ok. I got another main board and NVRAM from another machine, works great! My only problem is that the counters are way off due to the old machine. Is there a way to change them to match what the were before?
                Kelly
                • TonerMunkeh
                  Professional Moron
                  • 3865
                  The counters are stored on the NVram. If you want the machine fixed for good, replace it with a new one.
                  Hit it.
                  • teebee1234
                    • Jul 2008
                    • 1670
                    You could zero out the current meter and add all future readings to the last recorded good meter or use the mechanical counters going forward. In any case, document it somewhere where future techs will be sure to see the change (write it with a Sharpie on the inner cover maybe).
                    • Alex1
                      • Oct 2012
                      • 285
                      Re: nvram
                      Kelly
                      I tried cloning from another exact model worked fine
                      • Iowatech
                        Not a service manager
                        • 3930
                        Re: MPC3000 Username and Password Needed
                        I don't know if this machine does, but a lot of machines have mechanical counters.
                        • pro.b.unal
                          • Dec 2008
                          • 42
                          reset the supervisor password procedure. (NVRAM reset procedure)
                          Print out smc non deafult list on the mpc3000.
                          Because this procedure reset the all data for example counters, IP numbers, passwords and all sp mode
                          1. remove the nvram (ont the MCP3000 machine)
                          2. this nvram install the mp 7500 series machine
                          3. Turn on the main switch MP7500
                          4. Please wait hold the 1 munite near the MP7500
                          4. Turn of the main swictch
                          5. This nvram instal the MPC3000 machine
                          6. Turn ont he main switch
                          7. Enter the SP mode register 5985-1 and 2 set to 1
                          8. ;Enter the serial number
                          9. Enter the smc non deafult list
                          10. Register 2-111-3 and 1 execute
                          Please can you try it, I try a lot af and no problems
                          execuse me , I know my english very trible
                          • skynetto
                            • Sep 2012
                            • 257
                            You should know VERY WELL that this is very sensible information. SOME THINGS SHOULD REMAIN SECRET. So please delete it as soon as you can.
                            • johnyb
                              • Feb 2011
                              • 167
                              PM Sent
