2232c Cyan background on card stock
  • tinfox
    • 317
    Doesn't do it on regular paper. I replaced cyan dev.
  • Vulkor
    • Jun 2009
    • 946
    Cardstock putting extra pressure on transfer Unit cleaning blade. Check their for Cyan toner buildup perhaps. Also make sure customer is using Cardstock option in print preferences.
    • taskalfaman
      • Nov 2009
      • 137
      hi,
      special firmwareis avialable.
      please update the machine to the latest version available.
      check sim 325
      set it to on
      set the rank to mode 5
      set bypass to thick paper.
      problem was solved in my case.
      this is only the case for this type of machines.
      same fenomena, solved by soing these steps.
