Ricoh MP-C3000
  • T911
    • Jun 2007
    • 628
    [Jamming] Ricoh MP-C3000
    have a jam B i can't get rid of. there is a hole on the top side of the fuser cover that the sensor shines in at but it looks like a reflective sensor. I covered up all other sensors on the entire right hand side of the machine and all were recognized, triggering a different jam letter. Should i move forward with ordering the jam b sensor, doth they fail alot because it is right above the fuser unit. thanks t
  • TonerMunkeh
    Professional Moron
    • 3865
    I think that little hole is what the thermopile looks through to detect the temperature of the belt, paper doesn't (shouldn't) go anywhere near that hole. Does it jam from all trays on all paper sizes? Also, a jam at that sensor should register as C. Where does the SMC say the jams are?
    Hit it.
    • Fearless V K
      • 620
      Look for the offending sensor in Input mode.
      Don't take that toner with me!
      • Copierdocisleofman
        Senior Technician
        • Aug 2009
        • 86
        This may be a silly question but have you opened and closed all the covers, Ricoh's can be annoying about making sure you have opened covers and looked for the jam - especially the front cover, even though you can't unjam any paper from there. Could also be a faulty/dirty sensor - worth checking out the input values for sensors in that area using input mode as suggested by fearless
        • T911
          • Jun 2007
          • 628
          went back yesterday and got the right side of the machine naked and when i looked at the wiring harness at the lower right i saw a sliced wire. repaired and all is good. help much appreciated. thanks t
          • Vulkor
            • Jun 2009
            • 946
            Wonder how the heck the sliced wire occurred? Someone been working down there recently and forget to secure the harness in the loom properly?
            • T911
              • Jun 2007
              • 628
              volkur, thats exactly what i thought. someone f----d with that area. thanks t
