Aficio 1124c with SC 481 and 440 codes
  • portviking
    • Sep 2009
    • 18
    I am following up on a previous tech's call. He has replaced
    AX060224 Main drive motor, AX060283 DV drive motor, AX210088 4 Clutches, G0704700 Main drive unit , B2142302 PCU unit, AW010135 belt sensor, B1546160 sensor bracket, B2142161 main charge and B0515107
    IO board. Firmware has been updated and the clip for the cam has been replaced. also verifed that CN 307 is fully seated.The code comes up each time when the yellow assembly contacts the belt during the developer cycle. Any ideas is REALLY appreciated.
  • iMind
    Vacuum Cleaning Expert
    • Mar 2008
    • 1116
    Hang yourself... hehehe
