problem with ricoh 2232c
  • bindarian
    • Mar 2010
    • 16
    Hello, i am having a problem with the copier saying to add yellow toner.
    I have tried 3 different cartridges, I also disconnected the lines and blew them out.
    It is like it is clogged somewhere.does anyone have any ideas?
  • teebee1234
    • Jul 2008
    • 1670
    I think your next step should be to replace the toner pump above the dev assy in the back of the frame.
    • JustManuals
      • Jan 2006
      • 9838
      This Parts & Service manual can now be purchased for $11.77 and downloaded immediately after payment from The Internet's largest collection of manuals
      Paul@justmanuals.com
      • Copierdocisleofman
        Senior Technician
        • Aug 2009
        • 87
        The toner pump is definantely the way forward - the part number for that toner pump is B1013359 and Cyan - B1013358 Magenta - B1013357 Black - B1013356
        • neergish
          • 177
          Sometimes the drum positioning plate can get bent and not fully lock the pcu in so it doesn't engage the dev unit fully causing this problem. Something to check before you order parts, it is an adventure changing those dev pumps. Ive fixed this by putting sticky rubber pads behind the PCU so to push them in fully.
          "See if you can rent a spring hook and a phillips screwdriver it will make your life that much easier..."
