iam a tech and i have some problems lately with the 730 finisher on a aficio 650 machine. it works fine when it is used with A4 paper, but there is always a jam when it is used with A3 paper. the paper stops in front of the punch unit. i have changed all the sensors on the finisher, the stepp motors,the presures on the gear belts and finally the main board of the finisher. the finisher used to work fine with all paper sizes and its not the first i have seen with the same problem. any help would be great . thanx
