Ricoh Mp4000 (Sc 350 occurs at 100 copys)
  • Gesttech
    • Oct 2009
    • 123
    [Error Code] Ricoh Mp4000 (Sc 350 occurs at 100 copys)
    Hi Everybody
    Please can somebody help me to solve that problem sc350 at every 100copys. The matter is that when the user prints hundred copys the machine stop and display sc350. i replaced drum, charge roller & cleaner brush, cleaning blade, transfer belt & cleaning blade. Initialize the drum with sp 3001-002 but problem still occurs. Sc350. i checked the ID sensor connector, i/o board, Hvs board. But when i checked sp 3001-001 the voltage is 6.4mA instead of 13mA in default value. it ok or not. what i need to do now. Help
    Thanks a Lot
  • slot
    • Jul 2008
    • 341
    Have you given the mag roller a good clean up and do the copies look good or are they a bit gray
    you may need to change the dev also as it only seems to last about 150k
    • Gesttech
      • Oct 2009
      • 123
      Hi slot Thank u For reply me
      Hi
      I changed developer. The copy looked very good. i clean the machine & vacuum some toner split.
      • katash
        • May 2010
        • 221
        yep,the mag roller on this mcn seems to always stain with toner a gud clean up and or change of dev.is required
        • dlums
          • 14
          If you do not come right, try replacing the id sensor, if that still does not solve it, you can look to replace the high voltage power supply for worse case senario.Good luck.
          • stephend
            Senior Technician
            • 306
            Check the position of the transfer belt lever. If it's in the wrong position the transfer belt will be in permanent contact with the drum and it will erase the patch. Also check the drum ground.
            • edgar226
              • May 2014
              • 1
              Re: Ricoh Mp4000 (Sc 350 occurs at 100 copys)
              Hello, a new part number for the mag roller ???
                • 37533
                This thread is 4 1/2 year old. It should be dead and buried. Start a new thread stating what problem you have and we will assist you!
