Help with MPC3300!
  • mrwho
    Major Asshole!
    • 4299
    [CQ] Help with MPC3300!
    I have this machine who makes some blur/jitter/whatever you can call it at the same location when printing on A3/DLT or bigger paper. I've attached some examples to better clarify what I'm talking about (I'm sorry about the size):
    Here's a good print:
    Here's a bad print:
    And here's the explanation for the bad print:
    Some observations:
    - Defect A appears when looking normally at the print; Defect B is noticeable only when light reflects at a certain angle (which is to say that when looking normally at the print, you can see A very well but B is barely noticeable)
    - Defect A varies in size - sometimes is less than a centimeter long, some other times can be 3 or 4 centimeters. Defect B is not always present in bad copies - or at least is not easily seen with naked eyes.
    - This is not an easily repeatable problem. The machine usually starts off well, then it starts to throw out a bad print in the middle of several good ones, until it finally spits a bad one every two prints, or worse. So, everytime I change something at the machine, I need to ask the customer to send out 10 or more prints so I can wait and see if the problem is gone.
    - I've got my brain fried over this one, so I can't think of anything else. Gonna have a good night's sleep and tomorrow I'll look at this again and answer any questions you guys can think of - or, hopefully, someone who already had this problem will post the solution to me. If so, I'll gladly pay you, anonymous helper, a cold one over paypal!
    Good night!
    Mascan42
    Ibid
  • Vulkor
    • Jun 2009
    • 946
    Sure looks like a Flat Spot on your Pressure or Heat Roller.
    • teebee1234
      • Jul 2008
      • 1670
      Ditto to being fuser related
      • Fearless V K
        • 620
        Try opening the entrance guide to it's max on the fuser. You can also mess with the fuser and registration motor speeds if you are adventurous and see if it makes a difference. (These were detailed in a some TSB's from the older machines that were having DLT issues). Does the problem happen if you run in 'thick' paper mode?
        Don't take that toner with me!
        • mrwho
          Major Asshole!
          • 4299
          Do you think that is easy to check just by looking at the fuser, or by rotating it by hand?
          Already tried the entrance guide adjustment and messing with the fuser speeds, without success. Can try the registration speed, also going to check for DLT issues on older models. The problem ocurrs both with normal and thick1 paper, and also by running the same thick1 paper with thick3 setting.
          Thank you all for your feedback - going now to the customer. Will keep you posted.
          Cheers!
          Mascan42
          Ibid
          • mrwho
            Major Asshole!
            • 4299
            Problem solved - That specific kind of paper required the "Paper Type" on the driver to be configured as "Coated" - customer was using "Thick 1".
            PS: Don't you guys get both mad and relieved when a solution to a problem you've been following for days turns out to be that simple? Relieved because it's solved, but mad because the solution was so simple all along?
            Cheers!
            Mascan42
            Ibid
            • Vulkor
              • Jun 2009
              • 946
              HA! Knew it was fusing related. Just not hardware, but Software. Those settings make a big difference in pressure, timing, heat, etc
              • mrwho
                Major Asshole!
                • 4299
                On a side note, I'm keeping the cold beer since no one found it. In fact, I'm drinking it right now!
                Mascan42
                Ibid
