Ricoh Mp4000 Sc 350 occurs
  • Gesttech
    • Oct 2009
    • 123
    [Error Code] Ricoh Mp4000 Sc 350 occurs
    Hi everybody.
    My customer have machine Ricoh Mp4000, the problem was sc350. when they done several copies, the copies is ok but sc350 occurs & coming unexpectedly. When i open the right cover i saw a patch (line)on the transfer belt. The drum is clean. Help me for solving this problem thanks. i replaced drum, developer,cleaning blade, charge roller +cleaner brush, transfer belt +cleaning blade. The Id sensor stay between 6.5 to 6.3. dont know what to do?
  • Herrmann
    • Jan 2006
    • 792
    did you clean/replace the id sensor? seems, that the problem is in this area. pinched wires?
    If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
