Printing Envelopes on Aficio MP C5000
  • itBgary
    • Jul 2025
    I am using MS Publisher 2007 and am trying to print Com10 Envelopes through our Aficio MP C5000. My envelope orientation always prints opposite of how I have it set. I need to run the envelopes through the bypass tray in Landscape orientation, but it only prints in part as if it were Portrait. Is there any way I can change this?
    • 23002
    I'm guessing you're using a PostScript print driver, and MS Publisher can produce some very strange results with a PostScript driver. On one occasion I had a customer printing duplex booklet layout from Publisher, to ledger paper. The 8 page letter size original document resulted in single ledger size page in which the images of pg 2 and 3 were overlayed, pg 1 & 4 were overlayed, pg 6 & 7 were overlayed, pg 5 & 8 were overlayed. Switching to a PCL driver emulation solved this problem for me.
    Another option is to use another application to send the print job, i.e. MS Word. =^..^=
    • itBgary
      I was using a PS driver. Switching to PCL solved it.
