rih 3025 fax error code 15-01
  • digicor
    • Jul 2008
    • 1159
    this says its a ntework error but the fax is still working and the network is still working, how or what is it and what is it affecting? how do i clear it? ihave noticed when it comes on the scroll says "dialing" and the memory goes down to like 91% but in the job log there is no rx going out or in progress.
  • jakpong
    Turned the POP3 server OFF in the File Transfer Menu.
    • Steve G
      • Mar 2010
      • 15
      Was Fax Forwarding set up previously?
      I've had this in the past where the authentication to a forwarding destination file has changed causing the file not to be transferred or the destination file or e-mail to have been deleted or changed.
      • digicor
        • Jul 2008
        • 1159
        thanks ill check it out, i have tried to fax forward to another number it worked once then didnt
        but the error code has always been there of and on.
        • tulipano
          • May 2010
          • 124
          contrlla il segnale telefonico
          • teebee1234
            • Jul 2008
            • 1670
            From the Knowledge Base:
            I receive an Error Code 15-01 or 15-03 when I select Facsimile Mode, what can I do?
            Answer These codes are associated with Auto E-mail Reception and normally occur when Reception Protocol is set to on even though this function is not being used. If you are not using Auto E-mail Reception follow the steps below:
            1. Press [User Tools Key]
            2. Select [System Settings]
            3. Select [File Transfer] tab.
            4. Select [Reception Protocol]
            5. Select [Off] and press [OK].
            5. Press the [User Tools Key] to exit.
            Note: Auto E-mail Reception is the polling of an E-mail address to receive the e-mails by Internet Fax. When Auto E-mail Reception is turned on the machine periodically checks the e-mail server for incoming e-mail and downloads it as necessary.
            • digicor
              • Jul 2008
              • 1159
              nice/thanks
