Is scanning to SMB standard equipment, or does it require an option, enabler, etc? By all appearances, scanning to email and PC should be available on the standard box.
If yes, I am assuming that the server hostname/IP, path, and login/password are settable in a destination memory location accessible from the web interface. I haven't seen the machine in person yet, but according to the IT onsite, the scan settings are not visible from the web interface.
Next question, where should I find the scanner destination memory locations? Does something need to be enabled before they become visible?
Last question, if the scan settings are truly unavailable when I get there in person, is there something short of replacing the NIC that can be done?
Thanks in advance. =^..^=
