MP5500 light spots
  • GhostInTheMachine
    • Feb 2010
    • 88
    MP5500 light spots
    I have a MP5500 that had light spots in a line down the page. Thought it looked like dead spots on the drum so I replaced the drum and that fixed the problem. However, the problem came back the next day and we now have a MP6001 doing the exact same thing. Could it be something environmental? Some kind of fumes? Anybody had any experience with this?
  • Fearless V K
    • 620
    Drum charge corona problem or development unit mag roller void areas come to mind.
    Don't take that toner with me!
    • GhostInTheMachine
      • Feb 2010
      • 88
      DV unit has been replaced. Maybe charge but why 2 machines at the same location?
      • Polo-022
        • Sep 2007
        • 484
        Connect the optional heaters for drum and optics.
        Set 3903 to 'on' (Drum rotation time extention) and 2964-1 (transfer/drum blade forming) to a higher value.(More powder on the drum..)
        Enable fuser idling mode to stabilize the conditions around the drum (1103 or 1104 SP mode).
        I had the same symptoms on MP5500 and AF-2075 in the past...i found that drum was covered by a thin layer of moisture.(wet paper heated all night from the tray heaters, maybe....)
        You really have a ghost in the machine!!!
