Savin SLP38cde new fuser reset procedure not working per instruction booklet.
  • Bri Ski
    • 48
    I am having one crap week with simple resets. Installed new fuser in this and tried following the instruction that came with it, but it doesnt seem to work. It is flashing "Adjust in maint. menu" so press menu says "check and print" and does nothing. The 11x17 paper is in the bypass tray. if you press any buttons while it says "check and print" It does nothing accept let you go to other menus and then after a bit it goes back to first message.
    Any way it does print beautifully but sure would appreciate any help on this. Thanks B
    Only guess is its easier on a ricoh
