Toner near end MPC 2000
  • secretweapon23
    • Jul 2010
    • 69
    #16
    try to check first the value of TD sensor:vt display(3-201) it should be not so far from the other color value. if then, try to calibrate again the TD sensor(3-013) select the color which having problem. or disable the toner end detection(3-045)and force toner(3-015) then test multiple prints/copies and put it back/enable again the toner end detection(3-045) check if still add toner.
    this maybe bug on the memory that the machine can't recover add toner problem.
    Anyone who has never made a mistake has never tried anything new.....A.E.
