Pro907ex cover sheets jamming
  • slot
    • Jul 2008
    • 341
    I have this pro907 that will run all day on d/plex or single sided from any tray but if the customer puts a cover sheet or back cover from any tray eg 2 or 3 the copier will jam at the reg area.I have removed and vac the reg sensor and turned off double feed the coier has 2.5M on the clock after 9 months and in that time has had a few full services and the tray 2/3 feed units have been replaced to get over the no feed jams these machines seem to suffer from> the firmware has been updated i am going back with a reg mylar guide that normally wears on the older modles but if this fails dose anyone have any other ideas thanks in advance
  • _Brent_
    • Jul 2009
    • 39
    Do you have the jam code associated with the problem ?
    • slot
      • Jul 2008
      • 341
      the codes are 69 paper bank relay s and 20 reg sen and 10 first tray transport
      • tcs04
        FORMER Techie
        • 1183
        If copying onto the covers, try using "designate sheet copy" instead of "cover sheet" as a test.
        If not coping try "Insert sheet" before / after.
        Which stock are they using? Glossy? heavy?
        Single or double sided covers?
        Paper type / thickness set correctly on the tray display? (Silly, but had to ask)
        • slot
          • Jul 2008
          • 341
          i have tried it on single and double same result the paper is standard 80g i have also tried just using white paper in both trays good idea about trying designated sheet ilike your thinking
