Ricoh Aficio 2090 Loss of Power
  • Oscar57
    • 79
    Hi everyone,
    The copier does not start up, the MAIN power light lights up but the ON light next to it does not. I do not have a screen. Does anyone know the order in which the power goes into the copier.
  • _Brent_
    • Jul 2009
    • 39
    Any noise upon power up, printer goes through initial boot up/warm up routine or is printer simply quite with the one power indicator on ?
    • Oscar57
      • 79
      Just quite, no start up
      • _Brent_
        • Jul 2009
        • 39
        I had that happen one time. I ended up replacing the power supply PCB2 AZ250017, item 1 in the JPEG. You may want to verify the CB near the finisher on the left rear of the machine and reseat all cabling or possibly power up without any options connected, finisher, LCT, to verify problem is with the engine and not the options.
        • Oscar57
          • 79
          Thanks I'll give that a try!
          • _Brent_
            • Jul 2009
            • 39
            I was a little vague on the part about reseat all cabling. I should have said reseat all interface type cables, ADF, LCT, communications, etc-no internal cables. Sorry about that.
            • tcs04
              FORMER Techie
              • 1183
              Originally posted by Oscar57
              Hi everyone,
              Check the 24v (and 5v) lines into the op panel. Are any fans running? Also try removing the data cables from the hard drives and see if the machine runs further into the boot sequence and shows a HDD code.
              • flo
                Engineer
                • Mar 2009
                • 44
                This Machine have two Extra powerswitch One on the side from Tonerbank and another in the middle of backside
                down from the board, its possible u hit this one and finaly machine go to power but u dont have a touchpanel and u hear the processing dont beginn
                look at this i saw this two times by engineers and show them this
                all this machine works fine now
