ricoh sc440-o2
  • digicor
    • Jul 2008
    • 1153
    ricoh sc440-o2
    ricoh 3245c error code 440-02 is on , what is this code related to?
  • Vulkor
    • Jun 2009
    • 946
    Color Drum
    No drum gear position sensor
    signal is detected within 0.8
    second (C2a/k: 125 mm/s,
    C2b: 162 mm/s) or 2.0
    seconds (81 mm/s).
    • Defective PCU
    • Defective drum motor
    • Defective drum gear
    position sensor
    1. Turn the main switch off and on.
    2. Check and/or replace the PCU.
    3. Check and/or replace the sensor.
    • teebee1234
      • Jul 2008
      • 1670
      I can almost guarantee the drum motor failed. I keep one in stock, the new ones have a shield to protect the circuitry. Attached is the tech bulletin...
