RICOH MPW 2400
  • romnick
    • Aug 2008
    • 56
    RICOH MPW 2400
    Hello friends i need some informations from you regarding MPW 2400. I installed already the machine without roll feeder. From backside of the machine i saw 2 outlet
    one for RJ 45 and one for USB. My question now is, Can i run this machine as a printer
    without installing the printer option type W3600, Thank you because im too much
    confused.
  • Steve G
    • Mar 2010
    • 15
    The NIB and USB support features are built into the GW controller board. However, these features cannot
    be used until they have been enabled with SP5985: to activate set this SP to 1.
    The print options that can be fitted are :
    Printer/Scanner unit Type MP W3600 (Embedded)
    Printer unit Type RW-3600 (External Ratio Controller)
    The 1st option would be also activated by the standard SD card (Either Service Slot 1 or 2 ) which I presume, is the option that you purchase for Network Printing & Scanning ...
    • romnick
      • Aug 2008
      • 56
      Sir, you mean to say that i can use this machine now as a simple printer but not network printer. Is this what you mean.
      • Steve G
        • Mar 2010
        • 15
        My apologies,
        Firstly the SD Card activates the Print Scan Function on the MPW, then check the SP to make sure that the Embedded USB/Network ports are enabled.
        • Vulkor
          • Jun 2009
          • 946
          If it doesn't have the Printer/Scanner SD Card in it then no. Many Ricohs come with USB and Network Cards but are not activated.
          • romnick
            • Aug 2008
            • 56
            So, to make it clear to me,you mean to say that i must install still the Printer/scanner option Type 3600 and 3 SD cards. Is it right? sorry still really confuse. Thank you to all.
            • zed255
              How'd ya manage that?
              • 1024
              The USB and RJ-45 connections are standard. They may need to be enabled using SP5-985-1 (NIC) and SP5-985-2 (USB), by setting these values to '1'.
              To print and scan you have to add the optional Print/Scan Type 3600 kit, which is basically an SD card and some key tops for the operator panel.
              If there are other options to complement the Print/Scan option, then those SD cards have to be installed also. There are only three SD slots on this machine which means that if you have more than three SD based options you have to 'merge' the applications from one card onto another to free an SD card slot. The application move is performed by putting the 'source' SD card in the service slot and the 'target' SD card in slot one, then running SP5-873-1. Once the application is moved from the SD card in slot three to the SD card in slot one. The card in slot three is removed but kept as it is your proof of purchase. Slot three should generally be left vacant for service use if possible, but options will be recognized by the machine if slot three is used.
              • romnick
                • Aug 2008
                • 56
                Thank you very much for your replies, now i understand that i need to install first the SD cards to run this as a printer/scanner.
                • tcs04
                  FORMER Techie
                  • 1183
                  Press the User Tools button (The one marked "123") If you see "Printer Features" (Or similar) on the screen, you have a Printer card installed.
                  Go to system settings, select "Interface settings" to input the IP address.
                  • rsyarcia
                    Hair Straightener Tech
                    • 711
                    mr. romnick s. please read the service manual for add'l info page 101 to 109
                    SERVICE MANUAL Machine Code: B286. Neptune-C2, tnx
                    Nobody is perfect..
                    • mahabub
                      • May 2008
                      • 12
                      ricoh 2400
                      dear friends,i have also ricoh 2400 machine ,which i installed last week. customer he purches that machine with all option...but i m also confused about printer/ scanner..because i saw that macine have already usb and rj45 port but there is no printer/scanner sd card....customer he purches type 3600 printer and scanner but there is no sd card there is only two option card one is for machine and another one is for pc.................but customer want to use his machine with rj45 network.......now i m confused about with this option ........is this machine will work without sd card or if i fixed the option card ,network cable rj45 will work ? because customer dont want to fix another option card his pc......
                      thanks to all
                      • rsyarcia
                        • 711
                        1.PRINTOPTW3600 Print Option Type 3600 (GW)
                        (Requires either ROLLFEED240A orROLLFEED240B– cannot combine with PRNTCONW3600)
                        WIRELESSH IEEE802.11B Wireless interface H
                        ( Cannot combine withGIGETHTYPA)
                        BROWSERTYPEC Browser unit type C
                        DOSTYPED Data overwrite security unit multi fit
                        SCANOPTW3600 Scanner Option
                        (Requires FFCTC)
                        GIGETHTYPA 1 Gigabit Ethernet interface
                        (Cannot combine with DIF802H)
                        FFCTC File Format Converter Type C
                        (Required for GW scanning or working with the Document Server via a WebImage Monitor or DeskTopBinder)
                        DIF7300USB USB Host Interface Type 7300
                        VMCARDTYPEE VM Card Type E
                        __________________________________________________ _______
                        2.PRINTCONW3600 Print Controller (RATIO)
                        (Requires IFTYPEW3600 Interface Board
                        ROLLFEED240AA or ROLLFEED240BA cannot combine with PRINTOPTW3600)
                        RW3600CGM CGM Option Print Controller RW3600
                        IFTYPEW3600 Interface PCB Type W3600
                        (Requires PRINTCON3600 Print Controller)
                        RW3600DWGOPT DWG/DXF/DWF for print controller
                        UPDWG360 Upgrade to DWG option for latest AutoCAD
                        RW3600PSL3 PS3 for print controller
                        RW3600SO Scanner option for print controller
                        RW3600VIC VIC option for print controller
                        please see above details and check wether you are using GW controller or Ratio print controller.
                        Nobody is perfect..
