Ricoh SPC410DN - Maintenance Reset Procedure?
  • prntrfxr
    • 1627
    Ricoh SPC410DN, SPC411 maintenance kit part 402593.
    Would you or one of your copier buddies know if there is a reset procedure after changing the fuser when installing this maint kit??
    Anyone know the answer to my boss's question (above)?
    Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
  • Philinghorn
    • Sep 2008
    • 29
    Hi,
    I pretty sure the counter clears it self when the new fuser is fitted. Make sure you have the right maintenance kit, the 410 & 411 have different fusers. They physicaly fit, but the machine comes up with an error if the wrong one is fitted.
    • teebee1234
      • Jul 2008
      • 1670
      Ditto what Philinghorn said, but if you need to reset it manually use SP7804-11 (fuser pm reset) and/or 7815-007 (fuser replacement counter reset)
      • prntrfxr
        • 1627
        thanks for the help, guys
        • Vulkor
          • Jun 2009
          • 942
          Yes Occasionally the PM Counter won't reset. This is usually do to a spring that is out of place on side of fuser facing wall. Just reset Pm counter as above.
