MPC 2500 ardf jamming int.
  • aabarnes1
    • Mar 2009
    • 620
    1 page always goes thru, 2 most of the time, 3 or more jams on either 3rd 4th or 5th page. Now i know what most of you are thinking but theres only 62k gone thru the adf in fact there's only 123k on the machine. Torqu limiter, rev roller and belt are all good, also that little black plastic flap that sits on the cork friction pad is good. Output mode checks ok so any ideas please.
    Grant me the serenity to accept the things I cannot change.
  • teebee1234
    • Jul 2008
    • 1670
    I have replaced the clutch on that particular model twice within the last 2 months. Part # AX210102. I also replace the one way that drives the pull out roller since I'm in there - # B7894261
    • Vulkor
      • Jun 2009
      • 946
      This the model with felt bad in the pit? If so any white paper dust in there will trigger jams.
      • aabarnes1
        • Mar 2009
        • 620
        The pit???
        • jonezy999
          just one copy??
          • Feb 2010
          • 952
          reckon hes talking about where the registration photo interupter looks into. It gets full of paper dust and triggers random jams.
          I have not failed. I've just found 10,000 ways that won't work. ~Thomas Edison
          • totoro
            • 568
            I second teebee1234. I too have replaced the feed clutch in a few of these ardfs.
            Totoro
            • msaeger
              • Sep 2008
              • 333
              No that's the MPC3500/MP4000
              • Fearless V K
                • 620
                I would still hit up all the sensors and clean the areas opposite them. check the manual to make sure you get them all. some can take some disassembly to get to.
                Don't take that toner with me!
