Ricoh Aficio 450 copy quality problem
  • m_donakov
    • 213
    Hi evereone i got to diferent copies when i copy or print counter list. I print it first it is ok and secound i bad, i atach pictures tooBad Print..jpgOK Print..jpg, once ok after that bad print or copy no meather.
    Is there is any posibility to be transfer unit problem ?
    or there are some service setings that i can change?
    Charge roller is changed so cant be charge roller problem.
    Developer unit changed cant be developer problem.
    Laser Unit Cleaned i dont think that laser unit is problem.
    And i dont know what to do
    Regrads
    Mile
  • TonerMunkeh
    Professional Moron
    • 3873
    Could be drum, possibly laser. When's the last time it had a FULL PCU rebuid?
    Hit it.
    • m_donakov
      • 213
      I think that was before one mounth ago,
      • TonerMunkeh
        Professional Moron
        • 3873
        Including developer?
        Hit it.
        • m_donakov
          • 213
          yes i have two diferen develope units and with bout of them the same thing hapen
          • teebee1234
            • Jul 2008
            • 1670
            Are the images being printed lef or sef? If sef, then I'm going to suggest that it looks like uneven transfer, as the bad print is weak on the side facing the rear of the drum. Check the front and rear pressure on the transfer roller. If printing lef, then it looks like it may be losing drum ground (usually the bearing holder for the drum shaft).
            • m_donakov
              • 213
              I try other drum same problem, i think that problem is samll roller inside in transfer roler it seems like blocked rold very hard is there is posobility that to be problem
              • teebee1234
                • Jul 2008
                • 1670
                Can you confirm what direction the paper is being fed, Long Edge First (portrait) or Short Edge First (landscape). Looking at your samples, if feeding short edge first then it looks like uneven transfer pressure. If feeding long edge first, it appears to be losing drum ground through the drum shaft bearing/bearing holder. Do a continuity check from the shaft to the frame and note the resistance, should be under a couple of ohms (rotate the shaft as you measure, you might notice severe fluctuation).
                • m_donakov
                  • 213
                  samples are portrait prints
                  • m_donakov
                    • 213
                    bit i open transfer unit two big rolers rotate well and easy, that smal roller somtimes rotate well, but somtimes not.Can that small roller do this? How to make big presure transfer roller to drum?
                    • teebee1234
                      • Jul 2008
                      • 1670
                      Generally I don't find that to be a problem, but you should break it down and clean everything and get it to rotate as freely as possible. With a poor drum ground (resistance is high but not open, the first copy/print may be good but the drum charge will not dissipate completely for subsequent images following. It will discharge too slowly which is why the first copy looks good, it has time to go to neutral from the previous job. But multiple prints, there is not enough time for the charge to dissipate. I would replace the drum shaft and drum shaft holder.
