I've had the same error and removed the punch unit....wound the motor back into HP and it fixed the issue...HOWEVER...I also found a set of small plastic guide wheels that had fallen out of...ummmm..."somewhere" and were blocking the travel of the Punch unit.
I removed the rollers from the paper path and as I said...wound the motor back into it's HP,reinstalled and it's run fine ever since.
