ricoh MFP CL 7000
  • DINGO
    • 661
    ricoh MFP CL 7000
    Hi friends
    I have a mfp cl 7000 that gives me error sc 680.,
    Can help me?
    thanks in advance
  • TonerMunkeh
    Professional Moron
    • 3868
    You may think I'm taking the piss with this solution, but are you using OEM toner? Apparently it's a chip misdetection error or a blown BICU board. Try a full set of OEM toners first.
    Hit it.
    • jonhiker
      • 661
      SC 680 BCU/ MUSIC communicationerror
      After the engine CPU sends a message, the Music CPU does not respond within five
      seconds three consecutive times.
      Toner cartridge memory chip looseconnection
      Memory chip problem
      Memory chip cable wiring problem
      1. Turn the main switch off and on.
      2. Check if the toner cartridge is
      installed correctly.
      3. Replace the toner cartridge.
      4. Check if the harnesses are not
      damaged.
      5. Replace the BCU.
      OEM toner X2.
      • DINGO
        • 661
        thanks friends.
        i use only oem toner, in this case ricoh.
        i will chek.
        my best regards
        • DINGO
          • 661
          thanks
          Hi
          was a chip toner misdetection.( i thynk)
          I clean a cheap surface and works,!!
          thanks a lot friends.
