ricoh 2045 sc 990
  • tulipano
    • May 2010
    • 124
    ricoh 2045 sc 990
    salve ho una ricoh 2045 esce il codice sc990, ho visto il manuale il codice siriferisce al sensore ID che non legge bene il tamburo. ho risolto cambiando il tamburo.
    questo problema esce molto spesso come posso risolvere ogliendo sc990 senza cambiare il tamburo?
    grazie x l'aiuto
  • bkwan101
    • Mar 2010
    • 21
    just change the new drum can settle this problem .hehe
    • tulipano
      • May 2010
      • 124
      scusa questa batteria qual'e'?
      • bkwan101
        • Mar 2010
        • 21
        english please~
        • anothertech
          • 1768
          • trc
            • Jan 2007
            • 95
            • tulipano
              • May 2010
              • 124
              Hi I have a ricoh 2045 sc990 out the code, I saw the manual code siriferisce the sensor ID that does not read well the drum. I solved by changing the drum.
              This problem often comes out how I can fix oglio sc990 without changing the drum?
              with the help x
              • jonhiker
                • 661
                Ditto anothertech. there was a service bulliten put regarding this problem and it also suggests replacing those switches.
                • tinfox
                  • 317
                  I just had this today. Replaced both switches.
                  • rednecktech
                    • 54
                    For future reference, what are the part numbers for these switches? Thanks
                    • tinfox
                      • 317
                      No clue. I took them out of a parts/test machine.
                      • jonhiker
                        • 661
                        1204 2521 and 1204 2529
                        thaose numbers are also good for the front door switches.
                        • rednecktech
                          • 54
                          Thanks!
                          • tulipano
                            • May 2010
                            • 124
                            sorry what are these switches? I mndi a pattern?
