MP C4500 Fiery
  • Donn0144
    • 14
    MP C4500 Fiery
    Can the Fiery be removed and the print/scan SD card installed instead?
  • teebee1234
    • Jul 2008
    • 1670
    It appears doable, never seen it done. Looking at the Fiery installation (done pre delivery) it appears you would need to remove the extension card that the Fiery plugs into, reinstall a memory dimm on the controller (1 of 2 removed during setup), and set sp5-985-001 back to "1". Then it should only be a matter of installing the print option.
    • Donn0144
      • 14
      Thanks for the info. I'll let you know if it works
      • KenB
        Geek Extraordinaire
        • Dec 2007
        • 3944
        I agree with TeeBee.
        I've needed to do this twice before.
        The kicker is to make sure you put the memory in. If you don't, it will never work.
        • msaeger
          • Sep 2008
          • 333
          And don't forget the print / scan buttons !
          • TonerMunkeh
            Professional Moron
            • 3865
            Imagine the service call where the customer's got a pen poking thru the ops panel...
            Hit it.
