SC 471 Error on Ricoh
  • fredy
    • Jul 2025
    On Ricoh Aficio AP 3800 after replacing color pcu. I start to get this error:
    SC471 Power on off // I verify that is no a electrical problem whit the swish: Can any body hell me whit this.
    Thanks to all
  • Cipher
    It's not easy being green
    • May 2006
    • 1309
    http://www.copytechnet.com/forums/ri...ode-sc389.html
    Covered in that post.
      • 23003
      SC471 is a Transfer Belt HP error. The transfer belt does not lift in the rear. The rear cam (G060 3894) slips past its locking tab on the square stepped shaft and slips off the side.
      Te fix: reposition the rear transfer belt lift cam to lock the tab into the square shaft. Secure the locking tab with a tie wrap.
      (Other possibilities:
      1) the transfer belt locking retainer may have been removed on setup-replace (G060 3687)
      2) the transfer velt home position sensor may be defective
      3) old style transfer belt transfer motor- replace (G077 3706)
      4) Replace transfer belt assy
      5) firmware to 1.18b or higher.
      • jeffreyozz
        • Mar 2007
        • 52
        exactly- check the cam
        • fredy
          Thank DAZ ;-)
          it really help, keep cheering the knowledge
          this what Internet is all about )-(
          • lisaonthelb
            coule u send me a pic of where this is located?
            • Cipher
              • May 2006
              • 1309
              Pretty pic.
              • lisaonthelb
                it is pretty but i still don't know where it is located. i appreciate you trying to help tho. i assume where it says savin is the front of the printer. lol could u tell me where to look from there before i get drunk? thank u again, lisa
                Originally posted by Cipher
                Pretty pic.
                • Cipher
                  • May 2006
                  • 1309
                  No offence intended but maybe you should just make the service call.
                  • lisaonthelb
                    I had a feeling u might say that..lol thank u for trying anyway!
                    • minolta35
                      Trusted tech
                      • Apr 2005
                      • 87
                      I had same problem.Customer cleaned the machine with air blower.And sc 471...
