Your thoughts on Ricoh MP 171 SPF
  • bauer
    • 72
    [Misc] Your thoughts on Ricoh MP 171 SPF
    We are considering the purchase of a MP 171 SPF for our office and would like to get some input as to the reliability and operating costs of this model. any input woud be greatly appreciated.
  • Jomama46
    • 2900
    Great little machine, set it and forget it.
    sigpic
    A+; Network +; PDI+
    • rthonpm
      • Aug 2007
      • 2849
      I have to agree. When my wife asked me for a small MFP for her business that was reliable and easy to use this was my only recommendation to her. I love these machines...
      • Leif
        • Jul 2010
        • 19
        It's a small machine, with a pcu life time 45k and fuser lifetime 90k.
        • jonhiker
          • 661
          good basic, low volume machine, no bells and whistles. copy/print/scan/fax all possible.
          • Jomama46
            • 2900
            so that might qualify as a few whistles. lol
            sigpic
            A+; Network +; PDI+
            • Vulkor
              • Jun 2009
              • 946
              I like them. We have many of them in the field. Only one CAVEAT.
              Don't ever lean on them, put pressure on them from the top or pick them up improperly.
              I've got two in my shop with broken scanner support arms and scanner frames. They are basically useless now and only good as printers.
              Also surprised none of you mentioned the issue with the ADF Double Feeding? We've replaced the spring plate per the bulletin along with motors, 1 way bearings, clutches etc and some still are iffy. We eventually superglue plastic wedges to make the spring plate firmer. It varies per unit. We try and try and test and test till it works right.
              • iMind
                Vacuum Cleaning Expert
                • Mar 2008
                • 1116
                • tekcopyer
                  • Nov 2009
                  • 35
                  Its a good machine but make sure your office wont print A3 size.
                  Everybody wants to go to heaven, but nobody wants to die.
                  • KenB
                    Geek Extraordinaire
                    • Dec 2007
                    • 3944
                    Good point! That one's surprised a few people already.
                    One cool feature, though, the little beast is a color scanner.
                    • bauer
                      • 72
                      Thanks everyone for your input.
                      • andy1mack
                        Senior Technician
                        • Jun 2010
                        • 17
                        Good little machine. From the 1515MF, the 161 and 171 I've heard good stuff from customers. It's a small convenient machine - don't try some off the wall application and expect it to work flawlessly. I find people don't want to spend any money and want everything. You get what you get. Good and reliable!
                        • Vulkor
                          • Jun 2009
                          • 946
                          Absolutely True.
                          • patrick_aab
                            Junior Tech
                            • 10
                            it is good reliable machine, up until you got an adress book data error then you need a new controller board. i've replaced 3 out in the field and i hope they were just a bad batch.
                            • jonezy999
                              just one copy??
                              • Feb 2010
                              • 952
                              Top boxes. Rarely have a call for these which isnt PM related. No A3 is a bummer. Display leaves a bit to be desired.
                              I have not failed. I've just found 10,000 ways that won't work. ~Thomas Edison
