developer in ricoh aficio-2090
  • tariq65
    • Jun 2010
    • 84
    Hi every one
    how to put developer in ricoh aficio-2090 and reclebrat progriming thank.
    plz helpe me.developer al most end.
  • mujibur
    • 53
    3.1.7 DEVELOPMENT
    1. Be careful not to nick or scratch the development roller.
    2. Place the development unit on a sheet of paper after removing it from the
    copier.
    3. Never disassemble the development roller assembly. The position of the doctor
    plate is set with special tools and instruments at the factory to ensure the
    proper gap between the doctor blade and the development roller.
    4. Clean the drive gears after removing used developer.
    5. Dispose of used developer in accordance with local regulations.
    6. Never load types of developer and toner into the development unit other than
    specified for this model. Doing so will cause poor copy quality and toner
    scattering.
    7. Immediately after installing new developer, the TD sensor initial setting
    procedure should be performed with SP2801 (TD Sensor Initialization) to avoid
    damage to the copier. Do not perform the TD sensor initial setting with used
    developer. Do not make any copies before doing the TD sensor initial setting.
    8. When using a vacuum cleaner to clean the development unit casing, always
    ground the casing with your fingers to avoid damaging the toner density sensor
    with static electricity.
    9. When replacing the TD sensor, replace the developer, then execute SP2801
    (TD Sensor Initialization) and SP2962 (Adjustment of Drum Conditions).
