Hi someone help me . About firmware for RICOH MPC 2500/3000 .I need it.
If you has it send to me please
Thanks first
Email:hosennet@gmail.com
Best regards
mpc 2500 firmware update
Joking aside, I have yet to perform this task. I wanted to the other day on a machine that I was working on in house, but did not get around to it. I have a machine that I want to set-up a remote firmware update through @Remote also. The machine isn't that far away and used sparingly so, I figured if something went wrong, it wouldn't be that big of a deal to get the machine going again.
I do all our updates through the use of the SD card method, when applicable. I have a 128 meg card with most all the machines different firmwares on it. This way, I just pop the card in and the machine does the rest. Anyway! Hope everything goes well with your update Leo!Leave a comment:
Be careful when loading firmware via the network. If a print job is sent or a fax comes through at the same time, very bad things will happen.Leave a comment:
thanks
cheers for that i will upload the firmware to it tomorrow, it beats getting out an sd cardLeave a comment:
If your going to do the remote firmware upgrade you use the firmware known as .rfu files. If you use the SD card use the .fwu files on the card.Leave a comment:
Hi guys, i am going to update the firmware on one of these machines and i know that you can upgrade the firmware via the web browser. My question is which firmware do you use, is it the remote one or the usual one?? (there are 2 types on the download site)
