Upgrade ricoh 551 to 700
  • Printerjunkey
    • Aug 2025
    [Misc] Upgrade ricoh 551 to 700
    cheers mates,
    I am in production printing and so far working on 2090 & 700, gem of machines!!
    I have few Ricoh 551, I have researched and found most of the parts are same. Can anyone pls guide me to upgrade them to 700, Do I have to upgrade the firmware, have never done it so kindly guide me how to do it
    thnx
  • teebee1234
    • Jul 2008
    • 1670
    Don't bother, you will spend more in labor and parts cost then replacing the entire box. Besides all of the boards being different (PSU, MCU, I/O), there are multitudes of individual parts that are different (pulleys, belts, brackets) due to the difference in speed.
    • Jimbo1
      • Mar 2008
      • 845
      That's the same machine except for speed and they aren't really that far apart. As for that 2090, hope you have some training because they get intersting.
      "Some days you get the bear, some days the bear gets you."
      Cdr. William Riker
      • kelvin3892
        • Mar 2010
        • 13
        Nothing different with parts, that only 1 jumper wire can upgrade to af700
        • teebee1234
          • Jul 2008
          • 1670
          My apologies, when I checked my parts guide, they also listed the B098 (ld055) on the same manual with different part numbers. I assumed that was the 700 (we know what they say about assuming). Any way, what jumper would that be that has to be cut?
          • shlo1
            • Jul 2010
            • 9
            you need to jumper two wires if you still need it i wiil check and send you the exact one.
            • ccchuah
              • Mar 2009
              • 158
              Open the back cover, look for the IO Board, behind it , you will see a connector board (A293-5140). Find a four pin connector with a three brown and one white wire, solder the first brown and second brown wire together.
              • Printerjunkey
                @cchuah.
                Thanks for the tip, shall update you guys on the outcome,
