2022 not printing
  • ash_572
    • Oct 2008
    • 523
    2022 not printing
    machine is copying fine but sometimes doesnt print from the pc. when i press the printer button on the copier it double beeps and the same with the scanner button. the document server works fine, sometimes after youve switched it off a few times it prints fine. i just dont know whaats causing this to happen. i checked on the back for loose connections and it seems fines.
  • TonerMunkeh
    Professional Moron
    • 3861
    Could be the HDD's stalling out. When it does it, can you see the option for printing and scanning in user tools and SP modes? Try formatting the HDD and reseating the memory DIMM's.
    Hit it.
    • ash_572
      • Oct 2008
      • 523
      u cant see the printer and scanner option under user tools and in service mode. sometimes the machine doesnt fire up after u switch it off, only the green light. after trying afew times it works fine and u can get into the printer and scanner option
      • TonerMunkeh
        Professional Moron
        • 3861
        I'd go for HDD first, memory DIMM's second, controller board third.
        Hit it.
        • Vulkor
          • Jun 2009
          • 948
          Before ANY of that Perhaps reload the FIRMWARE? I've had that fix this issue. Has the MFP received any SC 990, SC991?
          • Comatose
            • Jul 2010
            • 70
            If you loose printer/scanner option its the HDD
            • copyaction
              • Oct 2007
              • 996
              have you ruled out the customers network yet?
              • mlanier
                • Jul 2010
                • 11
                Another thing to try id re-indexing your HDD. have done this to around 40 HDD's and have not had anymore problems.
                • TonerMunkeh
                  Professional Moron
                  • 3861
                  I thought of that too, but it wouldn't make sense that the print and scan buttons disappear from user tools and SP modes. By the way - I meant reformat the HDD and reseat the DIMM's, not replace them.
                  Hit it.
                  • ash_572
                    • Oct 2008
                    • 523
                    you mean formatting the hdd? i have tried formatting the hdd already. today i went back to replace the hdd and did not make a difference, even disconnecting it. i remember coming across a sc990 once but that never re appeared again.
                    how do i rule out its not the customers network?
                    • copyaction
                      • Oct 2007
                      • 996
                      hook it up to your laptop and see if you still have the problem
                      • TonerMunkeh
                        Professional Moron
                        • 3861
                        Connect your laptop to it via a crossover cable and batter a load of prints at it.
                        Hit it.
                        • Venom
                          Technical/IT Support
                          • Nov 2009
                          • 765
                          Could possibly be a duplicate IP being used...try changing IP of copier if other tests have failed
                          IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
                          • aabarnes1
                            • Mar 2009
                            • 619
                            Could you explain re-indexing pls?
                            Grant me the serenity to accept the things I cannot change.
                            • ash_572
                              • Oct 2008
                              • 523
                              it was the memory dimm on the controller board that kept on failing. replaced dimm and fixed.
                              when i first got there i replaced the printer card first then switched the machine on. no change. so i then swapped the memory dimm that sits at the top of the controller board and that worked the first time i switched the machine on. and to confirm it was the memory dimm, i put the old memorydimm back in and when i switched the machine on, the printer and scanner wouldnt work.
                              thanks to everyone who tried to help
