mpc3500 jam code 17
  • bbapst
    • Dec 2008
    • 42
    mpc3500 jam code 17
    mpc3500 has intermittent jam code 17. only from tray1, only when printing/copying in color.
    leading edge of paper stops 1/4" out of registration roller. I have replaced registration sensor, swapped entire feed unit. any ideas?
  • delosangeles
    • May 2008
    • 274
    What is the engine firmware level and where in the world is this machine located?
    Trade like a tiger sleep like a baby
    • TonerMunkeh
      Professional Moron
      • 3865
      Was the feed unit you replaced a brand new one or one from another machine? There's an RTB (27 I think) to do with the sensors in the feed stations not being soldered correctly. Might be worth a look.
      Hit it.
      • Aneurysm
        Administrator
        • Jan 2005
        • 1091
        test
        • delosangeles
          • May 2008
          • 274
          Bulletin 27 has nothing to do with Jam code 17027
          • TonerMunkeh
            Professional Moron
            • 3865
            You're looking at the wrong machine. That's the Athena, not the Apollon. RTB27 for the Apollon has to do with the sensors. I know the RTB calls it a multi-feed, but this is the symptom I had and this is what cured it.
            SYMPTOM
            A multi-feed occurs.
            Note: In factory tests, the occurrence rate with the LCT is 0.08% (1/1239).
            Jam Position:
            [Tray 1] [Tray 2]
            CAUSE
            Vendor production error: The sensor’s detection circuit was not soldered correctly to the
            inside of the sensor.
            SOLUTION
            Production line
            The vendor changed the soldering method to ensure the connection is strong enough.
            Applied from: Nov, 2006 production (RAI)
            Action in the field
            Replace the paper feed sensor (P/N AW010128) with one that is not from lots
            FF08 – FK26. (06.06.08-06.09.26)
            Note: The stock of SPC has already changed to the modified sensor. The lot number is
            printed on the rear side of the sensor (see the photo on the next page).
            Hit it.
            • tcs04
              FORMER Techie
              • 1183
              NICE ONE!
              • delosangeles
                • May 2008
                • 274
                SYMPTOM
                Jam Position:
                [Tray 1] [Tray 2]
                CAUSE
                SOLUTION
                Production line
                Action in the field
                Oh you mean bulletin #2 for product code B801 maybe that will correct it but bbpast mentioned intermittent paper jams only when printing in color, I don't know. Hey where is bbpast he has not said a word.
                TECHNICAL SERVICE BULLETIN
                Page 1 of 2
                BULLETIN NUMBER: B801 – 002 05/31/2007
                APPLICABLE MODEL:
                GESTETNER - LCIT PB3010 for DSc525/DSc530/DSc535/DSc545
                LANIER - LCIT PB3010 for LD425c/LD430c/LD435c/LD445c
                RICOH - LCIT PB3010 for AFICIO MP C2500/MP C3000/MP C3500/MP C4500
                SAVIN - LCIT PB3010 for C2525/C3030/C3535/C4540
                SUBJECT: MULTI FEED JAM
                SYMPTOM:
                A multi-feed jam occurs.
                NOTE:
                In factory tests, the occurrence rate on the LCT is 0.08% (1/1239).
                Jam Position
                Tray 1 Tray 2
                CAUSE:
                Production error: The sensor’s detection circuit was not soldered correctly to the inside of the sensor.
                SOLUTION:
                Production line
                The soldering method has been modified to ensure a strong connection.
                Applied from: November 2006 production
                Action in the field
                not from the following lots:
                FF08 – FK26
                The lot number is printed on the rear side of the sensor
                NOTE: All affected sensors in stock have been replaced with the modified sensor
                • bbapst
                  • Dec 2008
                  • 42
                  Still fighting it. updated all firmware. regarding the feed unit, i swapped the unit from the third tray...continues to jam from tray 1 and works fine from tray 3, even swapped them back no change.
                  • delosangeles
                    • May 2008
                    • 274
                    Here is what the troubleshooting guide says about the B222 & B224 product
                    1. PAPER FEED ERRORS
                    Subject Symptom Cause Solution Note
                    Tray errors For PCL jobs if the machine
                    is in sleep mode
                    Printer firmware Install version 1.02 or
                    later.
                    See
                    B222/B224
                    Firmware
                    History
                    Jam 800mm paper or longer Engine firmware Install version 1.591:01
                    or later.
                    See
                    B222/B224
                    Firmware
                    History
                    Jam JAM201 Finisher firmware
                    SR3020/SR3030
                    B804/B805
                    Install version
                    02.030:16 or later.
                    See
                    B222/B224
                    Firmware
                    History
                    Jam Jam 111 Finisher firmware
                    SR3020/SR3030
                    B804/B805
                    Install version
                    02.040:17 or later.
                    See
                    B222/B224
                    Firmware
                    History
                    Jam Jam 17 Engine firmware Engine firmware Install
                    version
                    1.63:01
                    • TonerMunkeh
                      Professional Moron
                      • 3865
                      The tray 3 senor might have the same fault though.
                      Hit it.
                      • Leonh
                        • Jul 2010
                        • 11
                        have u tried the clutches on tray 1?Clutches are not part of the stations.
                        • ucinn
                          • Jun 2009
                          • 383
                          Check the mylar on the back of the paper guide at the registration roller. I've had those when they start to wear, they cause a burr which int. catches the paper before they finally get bad enough to catch it most times. I've had a few of these do that and it catches from tray 1 first because of the sharp bend it makes to get there from tray 1.
                          • bbapst
                            • Dec 2008
                            • 42
                            Cleaned clutch and problem seems to have gone away
                            • TonerMunkeh
                              Professional Moron
                              • 3865
                              I'd replace it, it'll do the same again soon.
                              Hit it.
