3245C depleting cyan developer units
  • Toner Boy
    • Aug 2007
    • 366
    When this happened the first time we blew out the connector and replaced the cyan DV unit and the cyan drum unit hoping to resolve the issue. Problem returned 2 months later, any thoughts? I don't feel like chasing my tail on this one. I'm assuming DV is being pulled to the drum, although customer never complained about image quality issues this time until the machine said 'set developer unit cyan' or something similar.
  • Herrmann
    • Jan 2006
    • 792
    The Developing Units are driven each by a clutch which tends to get sticky, causing your Problem.
    The Number is AX200273. You can try to clean it, or if in doubt, replace all 4 at once.
    If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
    • pLatik
      • 169
      or your issue is the motor pump who inject toner in the developer that is clogged
      • teebee1234
        • Jul 2008
        • 1670
        I cast my vote with herrmann.
        • bbapst
          • Dec 2008
          • 42
          dev clutch ax200273, i've replaced dozens of these for this problem. If you don't enjoy tearing the back of a 3245 off, I suggest at least cleaning(if not replacing) all the clutches while you're back there
          • teebee1234
            • Jul 2008
            • 1670
            If you read past the OP you will see that hermann already said the exact same thing. Still, your answer is correct.
            • Toner Boy
              • Aug 2007
              • 366
              Thank you all for the replies, I'll try the clutches and see what happens. It may be a while before we know for sure if that was it but from what I've read here it seems pretty clear.
              • bbapst
                • Dec 2008
                • 42
                just wanted to emphasize what a pain in the butt replacing the clutches are the FIRST time you do it. I learned the hard way, I replaced a black dev clutch and 2 weeks later I was back replacing the yellow one. Now each time I replace one I pull the rest out and clean them.
