Used toner case almost full, on ricoh aficio 450
  • m_donakov
    • 213
    I got message Used toner case almost full, on ricoh aficio 450, i alredy cleaned used toner that is behind transfer roller how can i clean thos message
  • TonerMunkeh
    Professional Moron
    • 3865
    SP2-960 switches the sensor off. Make sure you visit the machine regularly as the transfer waste will back up and wreck the dev if it gets overfilled.
    Hit it.
    • Jomama46
      • 2900
      Clean the contacts on the side of the xfer case. Common problem
      sigpic
      A+; Network +; PDI+
      • m_donakov
        • 213
        This Helps Thanks to all
