Ricoh 5560 copy quality help
  • CANCOUNTRY TECH
    • Aug 2008
    • 114
    Hi all.
    Have a ricoh colour 5560 giving washed out looking cyan magenta and yellow also getting white spots on copies when doing sky shots as well as sc496 which relates to music/id sensors.Have replaced charge rollers clean id/music sensors did not fix it.Dont see alot of this model if anyone has ideas experience it would be much apperciated.
    Cheers
  • Jomama46
    • 2900
    how many copies on the developers
    sigpic
    A+; Network +; PDI+
    • CANCOUNTRY TECH
      • Aug 2008
      • 114
      sorry forgot to mention drums and developer have only done 7k
      • teebee1234
        • Jul 2008
        • 1670
        White spots can be due to developer particles being pulled onto the ITB, but I've also have seen it due to the tranfer rollers under the ITB belt being contaminated - I tried to clean them with a cloth and fibers embedded into the spongy rollers (replacing the transfer rollers fixed that particular issue). Have also seen the front bearing that supports the PTR pop out of its frame, giving light copies - but mostly on one side. In any case, you should start over with a fresh PM with new developers and replace the ITB belt, transfer rollers in the ITB unit and the Paper Transfer Roller.
        You also mentioned that just the Y, C and M were light but not the black? Is it possible the ITB is not camming properly into position when color is selected (any errors noted)?
        • CANCOUNTRY TECH
          • Aug 2008
          • 114
          hi guys,
          Thanks for all the responses teebee was right turned out it was the toner attraction rollers in the transfer unit.
          Cheers
