Aficio 3245 Registration
  • daveyball
    • May 2009
    • 314
    HI
    I have an Aficio 3245 with lead edge probs, the machine had reg problems, so I changedf the clutch, and it stopped wandering, set up the lead edge, all good. If you switch the machine off, or let it go into stand by, when it comes on again the lead edge is out by a good 3-4mm. This is on black only, full colour is fine. Set it back up again, switch off, same fault. Any Ideas.
  • secretweapon23
    • Jul 2010
    • 69
    any sample copy you can possibly post?
    Anyone who has never made a mistake has never tried anything new.....A.E.
    • daveyball
      • May 2009
      • 314
      doc20100813103636.pdfAttached is a sample image, page one shows after power on and pre adjustment, page 2 after re-set up, you can run hundreds of pages off, and it's OK. As mentioned before full colour is OK
