Ricoh Aficio 2015
  • albasoul06
    Ricoh Aficio 2015
    Hi guys
    I'm Minolta Tech. but with today's economy our boss decide to fix any machine.
    ( I hope so )..... Today got a Aficio 2015. Need a part number or better a PARTS MANUAL
    is a black piece with a spring which give pressure to transport rollers and is located right on top of first tray if you take the front cover off you see that...( damn did not get a pic )... i guess this brake all the time because the paper is getting skew on fuser....
    TIA
    NICK
  • totoro
    • 568
    If you're talking about the friction pad the part number is B039 2711. It is the piece that sits under the feed roller and comes out with the paper tray. If not give me a picture and I'll try to find the number for you.
    Totoro
    • albasoul06
      Thanks TOTORO but is not the pad
      Is more a small LEVER with a SPRING which pull the transport roller in order to give pressure
      and if you want to take that off the only way is if you remove the front cover.
      Well if does not help you...will make a pic. Thanks anyway brother.
      • albasoul06
        Service Manual page 3-31
        Spring B hold the Registration Roller H....
        I NEED THE PART NUMBER FOR THE LEVER WHERE YOU HOOK THE SPRING
        • totoro
          • 568
          Is it a small bracket with 2 screws holding it in place with a hook for the spring that is to the left of the reg roller? If so, that is the registration roller bracket B039 2575.
          Totoro
          • albasoul06
            THANK YOU
            • totoro
              • 568
              Glad to help.
              Totoro
              • tcs04
                FORMER Techie
                • 1183
                It could just be the cassette guides out of position causing the paper to run too close to the rear of the machine, this is a common problem.
                Remove the paper lift plate in the cassette, remove the gear between the side guides, push the guides to the centre and refit the gear and plate. Cured?... lock the guides with self tapping screws.
                • mikadonovan
                  • May 2008
                  • 2931
                  He is talking about the front registration roller bushing. I have had them break many times on the B039's.
                  B121 front registration roller bushing P/N AA080269
                  NEVER ASSUME ANYTHING
                  • tcs04
                    FORMER Techie
                    • 1183
                    I think he said it was only from tray 1.... ?
                    • mikadonovan
                      • May 2008
                      • 2931
                      I dunno. He talked about taking the front cover off, and the bushing is black AND it has a spring attached to it.
                      • ronald2020
                        • May 2009
                        • 31
                        Mikadonovan is correct when it breaks it causes paper to come out skew cause of correct pressure at the rear end of the machine and a slight gap at the front end of reg roller
