ricohmpc2500 envelope feeding
  • digicor
    • Jul 2008
    • 1159
    i have a problem with the bypass feeding envelopes without crinkling the envelope.
    cant feed it portrait (sideways) it will pick it up but stops and jams on pper size isue,of course,but it does not crinkle the env, there is no env setting in the properties, i have tried all thick papaer settings, no good,any ideas?
    2) in word in office 7 on vista or wind7 the address prints at the bottom of the env, i have told the machine everywich way to put the add on the env, still ends up at the end of the env. could this machine need firmware updte? for the vista/win7?
    or this machine just doent do env's...
  • zed255
    How'd ya manage that?
    • 1024
    Envelopes are not officially supported. The fuser is what wrinkles the envelopes. Using a very high quality envelope may help but you would be better served by printing labels to apply to the envelope.
    • bbapst
      • Dec 2008
      • 42
      product support guide says envelopes can be run LEF in Thick 2 mode with the flap open.
      • KenB
        Geek Extraordinaire
        • Dec 2007
        • 3944
        ...but I wouldn't count on it.
        These machines simply don't do well with envelopes - they never have.
        • digicor
          • Jul 2008
          • 1159
          thanks guys somebody kill a salesman for me
          "this machine can do EVERYTHING" sign here...............
          • zed255
            • 1024
            What do you call a bus full of salesmen on the bottom of the ocean? A good start!
            • Ricoh-ono
              • 340
              If using a standard #10 envelope.
              Run the envelopes from the bypass face down, flap open, long edge feed.
              You will need to set the envelope size in MS Word to C5 to account for the open flap. Feed method should be face down and centered.
              You may need to select Thick mode if the toner doesn't fuse.
              I used this to fix the wrinkling problem a several accounts.
              Hope this helps.
              Do what you can, with what you have, where you are. ~Theodore Roosevelt
              • nmfaxman
                • 1702
                Was this a test??
                • digicor
                  • Jul 2008
                  • 1159
                  hahaha good one
                  ok thanks for info, ill tryit on monday am and let everyone know what happens,
                  "but the salesman said it was included","well the salesman said it WOULD make my coffee" LOL
