Hello to everyone,
I service a machine Lanier LD0105 the same with ricoh 2105 it is a 105 ppm machine.
It has worked fine and till now has made 5.650.550 copies but a week ago when i turn it on it says paper jam in R7 in the finisher and no paper is there jus i open the door and close it and the jam dissapear.
After i made some copies it says different time R7 paper jam with no paper stucked and after 2-3 times it puts the error code SC-738 and it finishes the job that you have putted than the eror clears when you restart the machine off and on.
I have seen the service manual but i cant solve this big problem of mine.
PLEASE HAS ANYONE ENCOUNTER THIS KIND OF PROBLEM?
PLEASE I NEED YOUR HELP!!!
