Ricoh Aficio 3035/Nashuatec DSm735
  • copier wizard
    • Jun 2010
    • 11
    [Error Code] Ricoh Aficio 3035/Nashuatec DSm735
    Can anyone help please.I have a m/c with error Sc542 what can cause this and how do you reset the code if fuser related,If this is via service mode how do you get into service mode on these m/c's ?
    Thanks in advance,
    CW
  • Yetno.0103
    • 63
    • totoro
      • 568
      Usually have this problem on machines that have bad or interrupted power. Clean and adjust the thermistors and follow Yetno.0103's instructions for reset. If that doesn't work then change the thermistors.
      # Reset Prosedure #
      Enter SP mode, and then turn the main power switch off and on.
      # Entering and Exiting SP mode #
      1. Press the Clear Mode key.
      2. Use the keypad to enter “107”.
      3. Hold down Clear/Stop for at least 3 seconds.
      4. Enter the Service Mode.
      Totoro
      • nqk
        • Sep 2010
        • 26
        press yellow key
        dial 107
        hold c for 5 sec
        click copy sp mode
        of your copier and again on aftar few sec
