add scanner module
  • platinumaa
    • Aug 2025
    add scanner module
    i have an ricoh aficio mp w2400 large format machine... it doesnt scan.. can the scanner module be added? if so, what is a guesstimate on the cost?
    thanks
  • delosangeles
    • May 2008
    • 274
    Big bucks
    thanks
    Big bucks my friend. If you like I can quot you cost on Tuesday when every one is back to work after the Labor day holiday.
    Trade like a tiger sleep like a baby
    • platinumaa
      big bucks... would it be under $200?, $500??
      • teebee1234
        • Jul 2008
        • 1670
        You'd be more in the ballpark if you add an extra zero to those numbers and then maybe double it...
        • platinumaa
          wow... the machine was only $5000.. and its in mint condition..
          • teebee1234
            • Jul 2008
            • 1670
            I'm sure you can get it for much cheaper, I was guessing MSRP. But I can't see getting a good used one for under $1000.
            • KenB
              Geek Extraordinaire
              • Dec 2007
              • 3944
              Right you are, TeeBee!
              The list price for the black and white scan module is just over $2,000.
              The color one is a bit over $3,300.
              Either would require a media format converter board, and it comes in at about $570.
              Again, these are list prices for new stuff.
              I'm sure there are bargains to be had out there.
              • delosangeles
                • May 2008
                • 274
                Labor
                He also needs to count the cost of installation by a qualified tech. I'm guessing he is just a end user.
                • platinumaa
                  yes sir.. im an end user... wonder if its cheaper to sell this one and purchase a used one with a scanner...
                  actually, i have another aficio that does scan.. its the previous model to my aficio mp w2400 though.. but it does scan to ftp/pdf.. is it possible to take the scan module outta that one (i think its the ricoh af 240w or 480), than purchase the media format converter board to install on my w2400?
                  i appreciate the knowledge by the way
                  • KenB
                    Geek Extraordinaire
                    • Dec 2007
                    • 3944
                    Good idea, but no banana.
                    They're different options.
                    • platinumaa
                      wow.. this is crazy.. theres got to be a way other than spending thousands of dollars.. its hard to believe that add on is going to cost just as much as the machine.. typically how much is a good used or refurbished aficio 2400 with scan option?
                      • delosangeles
                        • May 2008
                        • 274
                        Your ahead
                        Your ahead of the game if you paid 5K for the 2400. Finding used wideformat equipment are not easy to come by as their production is much smaller than say a copier or fax which all companies need to function. Any ways I can give you near wholesale cost or used cost on tuesday if you like.
