scans to folder
setup scan to folder on a mpc 2050. Only way i could get it to work is to set it up with IP example: \\192.168.1.xxx\scans. Now if i tried using the computer name say: \\user\scans it will not go through. now i can leave it for now but if that computer changes ip for some reason there scan to folder will not work!!
all machines on network are xp pro!! This is the only copier I've had to do it this way. Is there a reason why??
