savin 9955dp problem
  • gblack76
    I have a savin 9955dp reciently the print started getting very light no matter wether copying or printing off netwotk. Plenty off toner. I am not a copy tech this is my personal machine i bought used from a university. Any help would be apprecieted. If any body has a service manual I would be very gratefull
  • JOEYSULLIVAN
    • 20
    lite copies
    sounds like it could be dirty charge roller or developer is needing to be changed. If its developer, that needs to be dumped and recalibrated. also check for a dirty slit glass that could also cause lite copies and or blank streaks from toner dusting. A general cleaning from a tech works wonders if its been a long time since servicing. Check the rear of machine for work historys most hide them there.
