MP161 freezes
  • ponto700
    • 144
    MP161 freezes
    Hi,
    1 month ago i sold one mp161 with 9000 copies and today the client fone me becouse he turn on the machine and makes few copies and after that the machine freezes completly. . To make copies again he needs to turn off and turn on again. i check all buttons and all are fine... what can cause this kind of problem!? the machine is not conected in network... they only use to make copies and to recieve fax.
    Regards.
  • Holesaletech27
    • Jul 2009
    • 101
    Is the IU almost empty of toner? Perhaps a memory issue? Maybe update the firmware. Is there a surge protector/power filter on it? I have a few of these in-shop. Only issuses I've had was bad main boards(blocks on the display only)...
    • Jomama46
      • 2900
      Maybe its going into "auto-off"
      sigpic
      A+; Network +; PDI+
      • ponto700
        • 144
        there is no signal of tonner..the machine is pluged direct, dont have any protector. this one you turn on and everything is fine but after few minutes the machine freezes.
        • Jomama46
          • 2900
          When you say "freezes", do you mean you still have a display but you cant copy? Is the Print button red or green at that time.?
          sigpic
          A+; Network +; PDI+
          • Holesaletech27
            • Jul 2009
            • 101
            Print out the saved data(saved fax numbers and such). Then see if there's a default reset, or an all memory clear that you can do. Remove any extended memory that may be installed (just for testing/troubleshooting), there may be a problem with it causing it to freeze. Unplug what ever you can(ADF, extra cassettes) to eliminate those as an issue. I know it sounds like an over kill, like how can an ADF cause a freezing issue?! lol, it most likely won't, but I like to be sure with off the wall issues like this. Does it have an HDD? I don't think they do, but don't recall.
            • ponto700
              • 144
              i still have the display... sometimes is red and somel times green.
              • ponto700
                • 144
                now machines is giving code sc982 (hdd construction error).. i unplug all from the main board and then conect all again.
                • Holesaletech27
                  • Jul 2009
                  • 101
                  See if theres an HDD format that you can do.
                  • Eric1968
                    • 2458
                    SC982 means : Localization Error. Fill in your location with SP5-807 (2=North America, 3=Europe, 5=Asia, 6=China. This error can also occur when you choose a display language that is inconsistent with the model.
                    A defective NVRAM can also be the cause.
                    • ponto700
                      • 144
                      Hi Eric,
                      I bought the machine in portugal and the client is using with englisg language.. he his using the machine since 05/08/2010 and only yesterday this problem begin.
                      i will check tomorrow and i will see where i can get a new nvram for this machine... here in mozambique impossible to get nvram for this machines.
                      Regards.
                      • Eric1968
                        • 2458
                        I would check if the machine is set to Europe. You can backup the engine settings to an SD-card and perform a memory all clear. After that reload the settings from the SD-card to the machine. If that doesn't work, I think you have to replace the NVRAM.
                        • ponto700
                          • 144
                          Eric,
                          what is the part number for the nvram for this machine? i have the parts cataloge and the service manual but cant find this.. can i use a normal sd card to performe the backup? becouse i have the old ricoh pci card and i never have this problem before.
                          thanks a lot for all your attencio.
                          Regards.
                          • Eric1968
                            • 2458
                            Use an SD-card smaller than 1 GB. I always use 512MB. About the partnumber, I can't find it either in the manuals. If I can get it I'll let you know.
                            • Jomama46
                              • 2900
                              Try this 1407-6732 from the 171 cat.
                              sigpic
                              A+; Network +; PDI+
