Ricoh problem
  • edgareddy
    • Jan 2007
    • 11
    Ricoh problem
    I have a problem with a Aficio 2045, it just started giving me an SC 672. I have changed the controller, the operation panel and I still have the same problem.
  • Tonerbomb
    AutoMajical Resolutionist
    • Feb 2005
    • 2589
    hard drive
    Mystic Crystal Revelations
    • edgareddy
      • Jan 2007
      • 11
      Sc672
      The hard drive comes with the controller and Like I said, I changed the controller.
      • tonyd
        hi its a common fault on this machine. change the power supply!!!!!!
        • jeffreyozz
          • Mar 2007
          • 52
          try reloading the firmware with the dipswitch one(i believe on the controller- look in the sm to be sure) turned on. That is what gooses gives anyway.
          • edgareddy
            • Jan 2007
            • 11
            Ricoh problem
            Thanx guys for all the information, I finally got the machine going. I booted the engine with dip switch 3 on the IOBoard and it did the trick.
            • laxlaw
              Re: Ricoh problem
              did you solve your problem, what did you do, as I have the same issue, thoughts ?
              • mikadonovan
                • May 2008
                • 2931
                Re: Ricoh problem
                The last post on this thread was more than a decade ago, and he already answered your question in his last post. Edgareddy might not even be alive now. Might want to start a new thread.
                NEVER ASSUME ANYTHING
                • Zaxxon
                  • 608
                  Re: Ricoh problem
                  Time to sell a new box.
                  Please start you post with brand, model, problem.
                    Re: Ricoh problem
                    PLEASE start your own thread... don't piggyback on someone elses
                      • 37560
                      Re: Ricoh problem
                      Looks like a new tech, joined today, trying to jack up his post count. If he keeps it up, I for one will just ignore him.
                        Re: Ricoh problem
                        been getting a lot of them lately ...and end users thinking they can 'fix-it' on their own.
                        • laxlaw
                          Re: Ricoh problem
                          OK, thank you
                          • vickter200
                            • Mar 2018
                            • 18
                            Re: Ricoh problem
                            Laxlaw, dont mind these two POS Phil and rimjob i mean slimslob. they tried to pull the same bull on me. Fuck them!
                            There's a lot of other great techs on this site..
                            • psteelers
                              • Feb 2015
                              • 38
                              Re: Ricoh problem
                              Thanks for making me laugh.
