Aficio 3235C won't print- no error code- data light flashing, red light nic internal
+ More Options
Posts
  • sabankosz
    • Aug 2025
    Help please- this one has me completely stumped- I have no error code, machine copies fine, but will not accept any print jobs. I can get into the web interface, and it says PRINTING, yet there are no jobs. I have reset machine, no avail. I have jobs in the computer ready to print, I can ping, no printing, the green data light flashes 20 times, then off, then again, then it goes constant. Any help would be great as I have whole office down now. Thank you.
  • mikadonovan
    • May 2008
    • 2931
    Cancel the jobs, reboot your computers and reboot the machine from the main power switch. Sounds like the machine doesn't like what your sending it. Any SC code associated with the problem?
    NEVER ASSUME ANYTHING
    • Jomama46
      • 2900
      Do you have user codes enabled for printing? Are thee jobs sent using "locked print"?
      sigpic
      A+; Network +; PDI+
      • copyman20
        • 207
        Agree with Jomama46. sounds like user code is on for printing or job being printed to locked print or Document server.
        • sabankosz
          no sc at all- no errors or alerts.
          The only thing i noticed when the green data light flashes, there is a red light inside the copier, the NIC inside has a light on it that flashes red, but i can ping it, I can get into the web interface, everything works.
          • TonerMunkeh
            Professional Moron
            • 3865
            Have you tried using a laptop on a crossover cable? Has an IP access range been defined? Do the PC's print directly to the machine or through a server? Check these out first.
            Hit it.
            • tcs04
              FORMER Techie
              • 1183
              Do they have other printers?
              Unplug the network cable and ping the copier I.P. Do you get a reply? This sounds like a duplicate address. If you can get a reply you will probably find the jobs printing elswhere in the building! Had a similar fault a couple of weeks ago.
              Of course the customers I.T will say they didn't change ANYTHING!!
              • sabankosz
                Thank you all- I had to turn off every damn PC in the building, as there were print jobs stuck everywhere in the computers, but not locked in the printer. I flushed the printer several times and that still did not work. It took me powering everything off in the building for 20 minutes as most computers rebooted and kept the bad jobs. I had to manually delete all the jobs and then power them all down.
                This was so odd- I have never seen a printer hang printing, yet have nothing in it- thank you all.
                Stephan
                • daveyball
                  • May 2009
                  • 314
                  Definatly sounds like user code or some sort of authetication, locked print issue, go into web browser, and check user code managment
                  • tcs04
                    FORMER Techie
                    • 1183
                    Stephan
                    As I said, I had what sounds like the same problem I had with a duplicate I.P! did you ping the machine I.P with the network cable unplugged?
                    • mlandry71
                      • Sep 2014
                      • 24
                      Re: Aficio 3235C won't print- no error code- data light flashing, red light nic inter
                      this is a corrupt print job clear all the print jobs from the computers unplug the cat five cable and reboot the machine
